Motorola Compression/Expansion Choices
BlueDevil
WA
Does anyone have any experience or suggestions with changing the compression (Disabled, Full Compression, ACG Mode) to improve TX/RX audio? Same question for the expansion setting (settings avail me above plus low-level expansion.
Any thoughts or is it a setting that really doesn't matter?
Thanks,
Brandon
firefive76
Kansas
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Here are my notes on this for the (Waris) Pro Series:
On the "radio configuration" menu under the "basic" tab make sure the "Audio Processing Filters" box is unchecked.
On the Conventional Personalities menu, select the "Advanced" tab. Make sure the "Compression" and "Expansion" types are disabled.
Then in the emphasis section, select "de-emphasis and pre-emphasis" as your option.
This is pretty much what Moonboots described for the Jedi's.
You will need to do this for every personality that has an audio issue. This should solve the tinny audio problem.
You should be able to convert these instructions to work on most other product lines. I had no problem setting up our CP200's (Commercial Series) to sound the same as our CMD1550's with these guidelines.
