Police (UHF) Frequencies -- What is their repeater offset??
drew4392
Recently became interested in listening to local law enforcement frequencies. It seems that all the frequencies listed in various online databases are the repeater input frequencies, as all I can hear are dispatch. Not individual officers.
This is in the UHF band.
Does anyone know what the offset is? I am trying to hear the repeater output frequency.
I thought it was 5 mhz, but don't hear anything so could be wrong.
Thank you!
rescuecomm
Travelers Rest, SC
In the UHF band, the lower of the listed frequencies should be the repeater output. Thus 453.300 and 458.300 as a pair, you should be listening on 453.300 mhz.
Bob
drew4392
Bob
Thanks Bob. Guess I'm not seeing a range in any listing of police frequencies. So is it safe to assume the offset is always 5mhz?
KB7MIB
Peoria, AZ.
453.0125-453.9875 and 460.0125-460.6375 are the outputs of typical UHF public safety radio system repeaters. The inputs are 5 MHz higher, at 458 and 465 MHz respectively.
That said, some agencies (L.A. County Sheriff comes to mind, who are in the UHF-T band at 483 and 486 MHz IIRC) use a two-frequency simplex system, or have the capability to disable the repeat function, where you have to have both the output and input frequencies programmed in, and be within range of the officers mobile and portable radios, in order to hear both sides of the conversation.
Another possibility comes to minnd. Is it possible that that agency has both an older UHF system that the dispatchers still multicast on, as well as a newer 700 or 800 MHz trunked system that does not patch the officers back to the older UHF system?
What radio system(s) are you trying to listen to?
drew4392
LA Sheriff is a good example. I am in LA, have attempted to figure out their system. I thought they use the usual repeater system. What I thought were the inputs being listed on all the different LE frequency listings... it would be easy to find where everybody is being repeated... just add 5 MHz and whalaaa... I have the output. But it wasn't working. So... what you suggest might be reality. They might be using a simplex system and/or using a newer trunked system that doesn't patch the officers back through what dispatch is using.
Hmm...
I'll try again tomorrow. Thought it was simpler.
ecps92
Taxachusetts
Offset - The RadioReference Wiki
Maybe your Agency disables the Repeater?
If you are hearing Dispatch then you have the Output
What Agency/Frequencies?
Thank you!
drew4392
Thanks for the link. It seems 3MHz could be it, as well.
My thought was since I was hearing dispatch, perhaps I was only hearing repeater input. Dispatch probably has stronger base stations.... or I am more line-of-sight with them and not patrol units. Otherwise, if I was listening to the repeater output frequency, I'd hear everybody. No?
LA Sheriffs -- https://www.radioreference.com/apps/db/?ctid=201
482.9125, specifically.
Thanks for the help, guys
DickH
It looks like the whole system is explained here:
Los Angeles County, California (CA) Scanner Frequencies and Radio Frequency Reference
ecps92
Taxachusetts
Yup, Repeaters are Disabled
NOTE: Mobile traffic is not rebroadcasted over the output frequency of the dispatch channels. Instead, only a beeping tone is broadcast to signify to the field units that someone is talking. To monitor units in the field you must program in the input frequencies also. The corresponding L-TAC channel is included in brackets.
mikegilbert
MHz so good
Los Angeles
As others have said, plug in the input frequencies for LASD and you'll hear the officers talking. Well, only if you're close enough to hear.
KB7MIB
Peoria, AZ.
And yes, it's a 3 MHz split in the UHF-T band between 470-512 MHz.
It's 5 MHz between 450-470 MHz.
If we had know what agency or specific frequency band you were asking about, you probably would have had the correct answer a little quicker :)
Just for future reference.
Good luck now that you have the answer!
