Pro 95 only scans one bank.
Para078
Tx.
My Pro 95 will only scan one bank. I've done a reset and it stil only scans one bank. Everything is unlocked and still nothing.
Any ideas?
W3DMV
Gettysburg, Pa
Been awhile since I used mine..
Do you have frequencies programmed in the appropriate banks ? If my
memory is correct there are a 1000 channels in the receiver.
Bank 1 is channel 0-99
Bank 2 is channel 100-199
Bank 3 is channel 200-299
Bank 4 is channel 300-399
Bank 4 is channel 400-499
Bank 5 is channel 500-599
Bank 6 is channel 600-699
Bank 7 is channel 700-799
Bank 8 is channel 800-899
Bank 9 is channel 900-999
If you have less than 99 channels programmed and you started with channel 0,
and ended at channel 98, then you only have frequencies programmed in bank 1.
and the selection keys on the front panel don't work...
Does that help. If not try again..
Good luck
Para078
Tx.
Ah, yeah. Put freqs in Banks 0 and 1, locked everything else out, and it stays on bank 0.
Now that's minimal, It doesn't receive anything, not even weather, paper weight time. I'll just add it to the pile of broken radios.
