Motorola to END production of CP 200/PR 400 Portable Radios***
CSFD390
Seneca, SC
Just thought I would pass along, that I recieved a notification from a friend via email, that Motorola will cease production of the CP 200/PR 400 radios on November 22nd, 2014. I know this is a pretty well used radio in my kneck of the woods, just thought I'd share the information!
kruser
West St Louis County, MO
Thanks for the info.
We also use many PR400's. They work well for the most part but were never quite as robust as the old GP300's we also had a bunch of for many years. I still have some of the somewhat rare narrowband GP300's in use.
I guess the next purchase will be similar TRBO models as our analog UHF and VHF repeaters are showing their age now.
I did a comparison test last year against the PR-400's and similar Motorola TRBO portables (can't recall the TRBO model though) and was very pleased with the performance of the TRBO models. I also don't recall the TRBO repeater radio model(s) but the TRBO radios outperformed the PR-400's repeater by a decent amount and that test had the TRBO repeaters antennas significantly lower then the PR-400's repeater for both the UHF and VHF repeaters of the same wattage. I was not expecting the performance increase I saw from the TRBO radios. I did not get to use the TRBO radios long enough to see how well they would hold up to the abuse some of our PR-400's see though.
I also have a few CP-200's on the VHF repeater. They have held up well also.
CSFD390
Seneca, SC
We just moved to xts 2500. & now xtl mobiles as we speak. ...I'm almost saddened to hear the PR/CP go away.... :(
Well that's not very good news. I know of a couple of people that use the PR400 on an LTR system with the MDC1200 signalling. They are happy with the radios and say they sound great. I wonder if they are coming out with something new to replace them with more features or trying to migrate analog users to the XPR series for an easier transition to DMR if need be in the future.
MTS2000des
5B2_BEE00 Czar
I'm surprised they ran the product line as long as they have. Motorola wants to migrate all entry level/pro users over to TRBO products. With the introduction of entry level TRBO radios like the CP-200D and XPR3500 portables, they are just as capable of all the features of the legacy radios including MDC1200, Quick-Call, etc.
kruser
That's my suspicion!
I still have plenty of PR-400 common spare parts so it will be a while before we make the move to DMR (TRBO).
Even though our analog repeaters are showing their age, the repeater radios can always be upgraded/swapped for cheap compared to whatever the TRBO repeater radio was I tested. The 2 slots per frequency was nice on the DMR radios though and as we seem to keep adding users, that would be the main reason I'd consider the swap to DMR.
The added range the DMR radios gave us was nice but unneeded for our application.
CSFD390
Seneca, SC
I agree..... but I will say this for us, the PR/CP IS NOT, I repeat, NOT a good public safety radio at all!!
kruser
Were either ever marketed towards PS use?
I don't know of anyone in the PS field here that uses these radios for that purpose. I've seen some local muni's use them for their public works departments though.
Our use is strictly industrial and entertainment support.
I'd say my number one problem was with the battery retention mechanism failing (mostly due to non-intentional user abuse). Also had a few 400's that had issues with very slow DPL decoding. That one was weird as CTCSS decoding worked very well. I think only 4 or 5 had the DPL problem. The local dealer could duplicate the problem but could not fix it. One took over a second before audio would open. They sent that one back to Motorola and they could also duplicate the problem but could not figure out the cause. They replaced all with the DPL problem and have been good radios for our needs. Even the ones with higher than normal abuse.
The few with the DPL issue were new so Motorola ended up replacing them after they could not figure out the cause. I think they wrote it off as a bad batch. The bad ones were all sequential serial numbers.
CSFD390
Seneca, SC
Nope....here it is either PR 400, CP200XLS, HT-1250, One fire district with Kenwood, & a department with XTS 2500 & 5000.
Peoria, IL
Our school district uses the CP200 radios to. I checked Motorolas website and it did not say anything about it being discountied. It should of said it. Like when they quit making the XTS5000 radios it said a cancel date on the product.
CSFD390
Seneca, SC
Yeah, quite possibly so. He told me over the phone, & emailed me a link, ill try to locate it and share...... but I didn't know they discontinued the 5000 series radio? I hope portable...cause I am currently searching for a updated cps for XTL 5000.
CSFD390
Seneca, SC
Wow....had no idea. I know that they are discontinuing the XPR 6550..? I believe that's it....I'd like to lay hands on one of those to.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
MOL has no "Intent To Cancel" notice posted for the CP200/PR400 yet.
Not saying your info is wrong, but more that this sort of thing is usually posted on MOL right away when it is released so it's a bit of a head scratcher.
KG4INW
Midlothian, VA
Motorola Solutions sent us the official email a few days ago (we're a Channel Partner) but I don't have my work computer with me right now. I can confirm they're canceling these as well as the CM300 mobiles. For some reason, MOL is down right now.
KevinC
Other
Super Moderator
Home
See attachment...
  • Cancellation Memo CP.PR.CM.PM. v1.0.pdf
