XTS3000 - CPS Read Block Help
jh73driver
California
Hi, I recently purchased a XTS3000 800 band. I am using Astro/Saber CPS R5 but when I try to read the radio, it shows "ERROR READING FROM IMAGE WHEN ATTEMPTING TO UNPACK BLOCK HARDWARD CONFIG SECURE BLOCK UNPACK/FAIL".
I am using a Ribless cable which has worked on other XTS3000 radios that I have.
Can anyone help me get past this issue to read the Radio so I can continue programing?
KevinC
Other
Super Moderator
Home
No help, but a XTS3000 can't do 700 MHz...just thought I'd let you know in case you wanted it for that purpose.
jh73driver
California
No error codes displayed. When reading radio, Radio shows 1 CSQ which is normal, right? Then the radio goes back to normal zone.
Then as the CPS is about to open up the Codeplug, the error box popped up (No code #)
jhal94
Pinellas County, Florida
Sounds like it wants to open it. 1 CSQ is the normal message. Does it "Bonk" at you by any chance?
Have you tried to ignore the error? It almost sounds like your CPS is corrupted. What version is it? The latest CPS is R05.03.00
jh73driver
California
The radio does not "BONK", but the computer does have make a quick sound. The only button to push on the CPS error message is "OK", which then brings you back to the blank CPS page with no CP open.
I have CPS R05.03.00. Maybe I'll try reinstalling the CPS. I used the Moto business solution online version that I downloaded from my account instead of the CD.... Is there any known errors in the download version?
jh73driver
California
I tried to reinstall CPS and the problem still remains. Any other suggestions or help on this error?
jhal94
Well that error makes me think it's having a problem reading the secure configuration data, if it isn't the CPS at fault it may be that your code plug is corrupted or something. I would try to send it to somebody (not me) that has Astro Lab RSS and see if that could open it. You could also bring it to a Motorola shop and see what they think.
jhal94
Haven't found a fix to the issue yet... Waiting for a rib cable and box to come in so I can try that route. Would that fix the issue?
Maybe, it just seems to me like there's a fault in the codeplug somewhere. If it doesn't work I recommend finding someone with depot to try and open it.
Edit: Have you tried to clone another radio to it? If it is a codeplug fault it may be overwritten with a limited clone. Also if you have a saved codeplug for it I would try to write to it.
