TK-5710H power amplifier smoked
wcu02mpa
Asheville,NC
My TK-5710 PA has a burnt component (a couple actually) and am wondering if anyone might know cost of the part. I can do the technical part, but have no idea of cost. I am also wondering if it is the same PA or interchangeable as the TK-790H?
Check your PM's, I might be of some help.
Different part numbers for the TK-790H "Final Unit" and the TK-5710H "Final Unit".
As for the damage, there are a number of components that could be damaged based on what caused it. Trying to diagnose it via one photo would be impossible. There are a couple of chip capacitors there between those coils that look like they smoked. Could be some damage to the coil itself. Who knows what else on that board got damaged, or if there is damage to the PC board itself.
wcu02mpa
Asheville,NC
It is damaged enough that I am going to have to replace the whole board. Pacparts has them for about $170 plus shipping. I have replaced enough boards that this one doesn't look that bad to do
mrweather
That's pretty extensive damage. Did the antenna lines get shorted out during transmit or something?
