Troop F Repeater On...ANyone else Notice ?
Mtnrider
Greene County New Yawk
Anyone Notice that what seems to be the Mt lodge ? Transmitter in in repeater mode ? Pretty neat hearing all the traffic from down that way.....when i can hardly hear our local ones...
APX8000
Sarcastic Member
AES-256 secured
Are they using repeater mode just on Schunnemunk or Graham as well? Same input PL or does a different PL activate the repeater? I know they used a separate PL for repeater mode for Jackie Jones in Rockland for special events.
riveter
MD
I think they're talking about the VHF tower being on mixer mode rather than the usual output-only mode.
APX8000
Sarcastic Member
AES-256 secured
Correct. The Troop F "base" frequency is now broadcasting the Troop F "car" frequency as well.
APX8000
Sarcastic Member
AES-256 secured
Well it was good while it lasted. It's nice to hear both sides of the conversation from NJ.
KC2zZe
Mid-Hudson Valley, NY
Repeater is back on for the listening pleasure of all....dont know how long it will last
My understanding of the system configuration is a little different. The so-called "Mountain Lodge" repeater is a standard repeater (in other words, not one that is turned on or off). In order for the barracks and the field units to use it they must switch to a particular channel in their radios, as you indicated above.
I do not think that the switch to Channel 16 and the police involved shooting in Brooklyn recently are unrelated. I believe an officer (trooper) safety concern is at play in the decision to switch over.
I am unaware, at this time, of a repeater at the Graham site.
Sounding good all the way into NJ again. VHF off Schunnemunk sure travels....
I'm sure that you were already well aware of that... ;)
APX8000
Sarcastic Member
AES-256 secured
I'm being told there was a problem with the duplexer up at Schunnemunk and a new pre-amp was being installed. Hopefully it will be back up. Sergeant that took over comms is a knowledgeable guy and is trying to push things forward.
