bravodenisu
- Joined
- Jun 11, 2012
- Messages
- 10
Hello friends!
I would like a long time to build my good scanner antenna.
I have thought about building a discone antenna. So I thought to build:
Screenshot by Lightshot
If you think something (size) wrong correct me. But these days I heard that if you add another element increases vertical jump band. If I make a calculated antenna for 27MHz it would come 27-450MHz reception. Everything is fine but the wire is too long 275cm to 27MHz !!!
And now a few days if I can still find something shorter wire and add a coil of wire built:
Or something:
If you know something more and knowing how to build this antenna discounts and how can I add the wire or pipe to be 27-450MHz please notify me and explain.
Thanks a lot!
Or something:
Thanks a lot!
