LTR Trunking and Radio ID's Question
peq387ab
Central Minnesota
I have a question in regards to LTR system and the radio ID's for the system. I have a Pro 197 and Pro 163 scanner, and I was wondering if there is a way that the radio ID can show up on the scanner or if there is a trunking software that will decode this?? I have Win 500, Unitrunker, and Pro 96 com for softwares, and right now I haven't been able to find anything that will work for this. Let me know if you have any suggestions on how I can get radio ID's for a LTR system.
Thanks!
KevinC
Other
Super Moderator
Home
Regular LTR doesn't have radio ID's, Passport however does.
If you want each radio to have a different "ID" on LTR you assign it its own regular ID (Area-Home Channel-ID X-XX-XXX). This can use up ID's pretty quick since each "Home Channel" can only have 250.
If you use this method and you want everyone to hear all the other units you set all radios to receive a "Block" of ID's (which must be consecutive).
DSheirer
Fulton, NY
Thanks!
Is the system LTR standard, or Passport, multi-net, or LTR-net??
peq387ab
Central Minnesota
I do, I was curious if they would have radio ID's behind be system, but I have been logging Talkgroups for the system with WIN 500 when they transmit.
phillydjdan
Couldn't they add a Fleetsync or similar radio ID in addition to the LTR? I've heard LTR radios emit a PTT ID similar to Fleetsync before...
KevinC
Other
Super Moderator
Home
Yes they could, but I assumed we were discussing native LTR.
