NX700 Transparent Mode
ab3ai
I've been experimenting with transparent mode on a pair of NX700 and I noticed there is a Transparent 2 (NXDN) mode. I've tried to get this working and have had no luck. I've searched around and haven't found any information on this. Can anyone explain what this mode is and how it differers to plain old Transparent mode and how to implement it? Also, in Transparent mode, what is the over the air speed of data on a analog channel in 12.5?
Thanks!!
Transparent 1 uses 80 byte packets.
Transparent 2 uses 314 byte packets
Transparent 1 would put a lot of delays/pauses and headers in, thus running slower data speeds. Transparent 2 would run fewer/larger packets, increasing throughput.
As for why it doesn't work on yours, you need to be sure both radios are set up the same. Same comm port, same transparent settings. If they are not matched, they won't talk.
From the Kenwood NX-x00 Function Reference manual:
The communication port of the transceiver assigned “Transparent” sends the received data automatically using the FleetSync protocol or NXDN protocol if the received data size exceeds 80 bytes upon the receipt of data from an external device.
The communication port of the transceiver assigned “Transparent 2 (NXDN)” sends the received data automatically using the NXDN protocol if the received data size exceeds 314 bytes upon the receipt of data from an external device. By using Transparent 2 (NXDN), data can be sent faster and more efficiently than by using Transparent.
Analog data transmission uses the FleetSync mode. There are two settings:
1200bps and 2400bps.
1200 is preferred as it's more reliable and works over a wider area. 2400 will work, but reliable coverage is reduced. More errors at that speed.
12.5KHz "narrow" NXDN mode will provide about 3700 bps
6.25KHz "very narrow" NXDN mode will provide about 1850 bps.
ab3ai
mmckenna,
Thanks for the reply and the info! That is good info to know. I'll have to make some changes to see how it works. I was able to get the link working. What I had to do was assign unit and base IDs and it went to work. We were able to pass files on simplex.
geicop
Brandon, Manitoba
Hi,
I would like to get more info about how to set up the transparent mode, I'm working in a project using 2 NX-700K, but I'm having trouble transferring data.
Do you have any resource where to obtain the configuration? or which configuration did you used?
Thanks!!
kd4efm
Florida
Geicop, email me, I have a set up sheet. What are you trying to do? I can use d-rats and do the same thing over NXDN as I can d-star.
kmsj13
Hi Kd4efm,
i was having a same problem with it, i have two nx700h and cannot transmit data over rs232 cable in tera Tem and in putty. any help?
