NM & AZ Aviation Contacts and Communications Guide
I noticed under the interagency some show narrow while others are not listed as narrow. So is most federal exempt from narrow mandate and some at wide still?
I tried these links for 2 days and they were dead. I thought someone found these posted and then closed access to anyone without a password. I saw your post tonight and figured you would post that the links didn't work. Now they are working again! I am a bit mystified by this. Mick and Bill it looks like the PM's I sent you two are wrong. My apologies on this one, however I've seen links go down elsewhere and I think my caution still applies.
If it were sensitive enough it wouldn't be on the home site in the open for interop. I think they are fine.
ecps92
Taxachusetts
Federal Agencies had to Narrowband long prior to the FCC Part 90 mandate.
I would assume Narrow, unless noted otherwise for 162-174 and 400-420 Federal frequencies
ecps92
Taxachusetts
Many agencies are undergoing redesign/web work and links come-n-go or get moved as documents change from doc to pdf or names get changed
I've seen files/links disapear for weeks, then re-appear. I doubt they (other than CAP) are following us that closely
kd7ckq
No. AZ
anyone have a copy of this that they could send me. I searched for it and it is no longer available anywhere.
kd7ckq
No. AZ
The ASFD is great to get started with WildFire monitoring in AZ and NM. I have the 2015 update, waiting for the 2016 update. The problems with the ASFD is not all the NPS, or USFS agencies in AZ or NM are Cooperators.
