When decoding NEXEDGE48 systems, UHF frequencies are assigned a channel number. Examples:
472.350 = CH 377
471.600 = CH 257
471.350 = CH 217
461.375 = CH 511
464.63125 = CH 865
Some of the numbers seem to have a pattern with regard to channel spacing and assigned numbers; some don't. Is there a listing somewhere? It would seem that UHF and UHF "T" band have their own listings. I tried to create a spreadsheet to figure out the numbering, but the numbers didn't match up to what was being reported in DSD+.
Hello,
I saw mention of a standard UHF Channel map in the product documentation. One of the local UHF system uses it, I document it here.
http://forums.radioreference.com/di...re/298075-understanding-nexedge-trunking.html
Otherwise each system implements their own channel map. I was listening to a wide area NexEdge trunked (Type-C) system up in Montreal with a channel map of over 250 frequencies. The map did not seem to follow any pattern but I did not receive many frequencies.
Standard UHF Map Formulas
For Channels 1 to 400:
Freq = 450 + (( Ch - 1 ) * 0.125
For Channels 401 to 800:
Freq = 460 + (( Ch - 401 ) * 0.125
In your case the system using Channels 511 and 865 is likely using the standard UHF map.
461.3750 = 460 + (( 511 - 401 ) * 0.125 )
464.63125 is a 6.25 KHz step frequency so it is in the custom part of the standard map.
After getting a few frequencies on the system, you can try the same techniques used to get the frequency mapping of a Motorola Analog VHF/UHF system.
( 471.600 - 471.350 ) / ( 257 - 217 ) = 0.00625 KHz (reasonable step size).
Base (Ch 1) = 471.350 - (( 217 - 1 ) * 0.00625) = 470.000
471.6000 = 470.000 + (( 257 - 1 ) * 0.00625)
472.3500 = 470.000 + (( 377 - 1 ) * 0.00625)
So the system has a Base (Ch 1) of 470.000 MHz with a 6.25 KHz step size. I do not know if the mapping is always divided into three parts (1 - 400, 401 - 800, 801 - 1023).
73 Eric
