Software Versions
BillKaye
Albuquerque, NM
Can anyone help me by explaining the differences between Programmer R20 and RPM? Do both versions require an activation code?
I wanted to program a 700P for P25 but it's one of the KRD models, and Programmer R18 does support P25 but only on the RU models.
So it's either buy a RU version 700P or a P7100, or try to see about getting a copy of R20, assuming it is reasonable.
Any thoughts?
Radioman96p71
Depends what you mean by P25.
P25 conventional can be programmed with ProGrammer. P25 Trunked cannot.
ProGrammer R18 was the last version that wasn't locked down with the current licensing system. R19-R20 and all versions of RPM thru R10 are licensed much more strictly.
Neither the RU version of the 700p or the first-generation V31-series P7100 can do P25 trunking, so you can stop there if that's what you are looking to do.
The V71 P7100 and everything newer P7200/7300 etc. can do P25-T if feature enabled and with the proper radio code/DSP.
Hope that answers your question.
greenthumb
Colorado DB Administrator
I'd have to go back a few versions to see, but I can say that ProGrammer R20 allows P25 trunked to be programmed. I's the old 'ugly' kind though with each site needing to be in a separate system if it's a multi-site P25 system instead of the "enhanced cc" found in RPM and newer radio code.
For the OP, it's kind of hard to find P25 P7100s on eBay, but that's probably your best bet.
snoopyII
On the other side of the tracks
I'm pretty sure the 700P does not support P25 of any type. The second generation P7100's came out mid-march 2005. They will have a F series DSP, the first generation will have a G series.
Also, R18 only supports P25C. It does not support trunking, even though it would lead you to believe that.
