FORD77
I just purchased a new BCD536HP and looking for cable to run from my antenna to the unit. I got a used discone antenna from my buddy and will be mounting it on the roof this weekend. The run will be across the roof, down the side, in the window and across rec-room to my listing station. Run is about 125 feet or so. Here is the question. what cable should I use? I have access to RG-58 however reading that LMR-400 is the best.... Don't have any access to that so would need to purchase online. Options? Just in case you need it here are my specifics. New BCD536HP, used radio shack discone, listen to pretty much just Colorado Springs Fire and EMS and El Paso County fire. Thanks for the help.
