VE3RADIO
Hello all,
So I have had this problem for a while now and have been using my work around for a bit, however I decided it was time to post this as I could not find any other fix or work around for it.
The problem is that the x36 series will not scan a new Harris phase II system in my area without a lot of manual intervention.
I have posted a youtube video showing the problem on both a 436 and a 536 scanner and the differences between how GRE will pick up the system and Uniden.
It should be noted although I did not mention it in the video.... even once I have the system working if i add another system of scan list then its right back to ground zero as once I leave the favorite list/system to scan another then the tower is lost again and I must use the site hold trick again.. needless to say this limits the ability to scan more than one system at a time.
https://www.youtube.com/watch?v=5bCljRXtMmQ
Hopefully Paul can watch this and take note.. perhaps others are having the same issues.
Please also note that the system in question was imported from the DB.. I have also tried making the system manually, only putting in one site etc.. nothing changes.
