First, make sure the frequency you put in is correct. The band plan programmed into your scanner indicates that 155.265 is not correct, and the nearest correct frequency is 155.2625. If 155.265 is correct, you will need to adjust the band plan settings in your scanner. You'll have to consult your manual; I don't have that scanner.
