Most of the times, the RID's are associated with the callsigns. Every now and then you will see them different, probably because of radio maintenance and such.
But as rkm stated, the system is a conventional linked repeater system that uses mixed mode. What you hear on one frequency will be heard on every other frequency in the system. They do have some simplex freqs, you will hear them say "go local" when they switch to simplex. 99% of all communications are P25 but they do have the ability to be analog if needed.
