Subliminal87
So radio shack listed the 436 for sale, I have gift cards so I'll order it from there.
I was originally set on the 536 after going back and forth for months. I've decided to get the 436 first, and either A pair it with a 996xt later on, or late late next year pick up a 536 just for the app (if it's there).
The 996xt would only really be to stream, or remote control. and 436 grab and go.
What do I need to know right away about this scanner, I really dug in the 536 about reading, but not the 436. I will just use the uniden software and maybe later switch over to Proscan.
I will be monitoring two P25 Phase 2 systems 700mhz.
One p25 Phase 1 500 Mhz.
One P25 Phase 1 400mhz system.
and one EDACS Standard system.
What type of cheap speaker is good for home that I guess needs plugged in since it needs to be amplified? It may not even be connected to a speaker at all at times.
How will the stock antenna work? Really have limited options for indoor since it will be moved room to room.
I had this for my car when I had the BC 15x and it was great.
SpectrumForce Wideband Antenna with Mag Mount and SMA
When it was on the desk I had this one connected and it was fantastic.
In-Car Mobile Antenna with SMA
obviously I had BNC's but would need the SMA versions now.
I thought if I needed to replace the stock one i'd grab this:
WSMA-801 Regular Gainer SMA Portable Antenna
Until my county system goes live I'll be monitoring 33mhz and 154-155mhz. I'll also hopefully be doing discovery to figure out our new system as they are getting it set up.
What should I know so there are no surprises? I had a 396xt but returned it, I hated the display. So I can only assume this one is much better.
What kind of display protector should I get?
I am going to use a spare iPhone charger to plug it in at home, and use my car charger adapter for my iphone for the scanner at times, will that be ok?
Any problems leaving the scanner on for hours at a time?this will be my only and primary scanner.
