motorola gp 380- from ebay
morrisonte
hey guy tootal noob here. i bought i motorola gp 380 off ebay got it today and its pre programmed with 4 grourps -shops,pubs shopsb2b and pubs bt , there are a few channels numbered kill when i go into it , just needing a bit of info :) i have ordered a usb programing cable for it , but what things can i do with it ?? thanks
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
The GP380 is a radio built for foreign (not North American) markets. From the description of the channels, it sounds like it might be a European model used in the UK.
Depending on where you are and what your licensing is or is not, you may not be able to do much with it. How about giving us enough information to give you a real answer to your question?
morrisonte
what info would you need , i just want to listen in to radio broadcasts, or is there anything else i can do with it , thaks for your help :)
SteveC0625
Where you are for starters. Then, do you have any licensing for the country you are in? Do you even know what types and frequency ranges of radios systems are in use in your area?
How do you plan to program this thing? It's a model for the foreign markets (not the US and Canada) and if you are, by some remote chance, actually in North America, that the European software is not available here. North American radio shops don't have the software, either.
MTS2000des
5B2_BEE00 Czar
FWIW, these do not do the newer "splinter" channels used in the USA, and are of course are not FCC part 90 certified like their US model counterparts, and require EU CPS.
I'd pass on these for anything other than HAM use, and only if you can find the software.
morrisonte
sorry guys , im in scotland the radio is motorola gp380 ,sw version R03.01.37 CP VERSION R4.05 SW PART NO 8266551A12 CP PART NUMBER 8266552A22. just wanting to know what uses i can get out of it , i have ordered the usb programing cable and downloaded the software . just needing a bit of advice on what i can do with the thing :) thanks
morrisonte
im in scotland its a moto gp380 sw version R03.01.37 SW PART NUMBER 8266551A12 CP VERSION R4.05 SW PART NUMBER 8266551A12 , im totally new to all this and was just looking for some advice on what i can do with it , ive tied Google and reading other posts . thanks for your help guys :)
SteveC0625
You still have not given us the model number. It's on a sticker on the back of the radio. You have to remove the battery to get to it.
Most, if not all of us are in the US or Canada. Very, very few of us has any useful knowledge of radio systems where you are, and the same goes for the laws around using two-way radios there.
If you have already downloaded the software, it's likely a bootleg copy. Very dangerous to use that. Motorola is very protective of its software and the only valid source is to purchase it directly from them.
Your purchased USB cable may or may not work with your computer. If you have a Mac, you won't have any luck running the software to my knowledge.
If the UK is anything like other countries, there are strict laws about transmitting on unauthorized radio frequencies. There are also laws about what equipment can be used in each radio service. The basic rule anywhere is that if you do not know for sure that you are authorized to transmit on any given frequency, then you are not authorized to do so. Unauthorized transmissions can easily interfere with police, fire, medical, and even military operations.
You need to hook up with someone locally who has some knowledge about these things and learn from them.
morrisonte
im sorry but there's no sticker on the back on the radio :/ im using a laptop with windows7/ a pc with xp . as i say im a total noob here , just got hold of it .if i cant find any viable use for it im willing to sell it if you guys like ?
spanz
I'm in the UK and the GP380 is a keypad/display/255ch conventional analogue version of the HT750 I believe. The proper model number will be something like: MDH25RDH9AN6AE / PW502H which is for the UK/EMEA UHF 4watt with keypad/display.
Morrisonte, unless you know the exact frequencies you want to listen to then you won't get very far.... this radio isn't a scanner where you can (easily) set it up to listen to all and sundry like a dedicated radio scanner would, but it's designed to be programmed with pre configured frequencies to transmit and receive on.
It can be programmed as a receive only radio but you still need to know the frequencies you want to be able to receive.
Might be worh joining Transmission1 which is a UK based forum for radio.
