XPR6580
jrmull93
New York, NY
I'm looking on ebay right now and there's currently a lot of 3 Motorola XPR 6580's for sale for under $100 the only issue the listing states that all three radios are locked and they do not know the password. anybody think its still worth it? I was doing some reading and it says that in order to reprogram it the password needs to be known.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Your reading is correct. Pass on this. It appears to be a Canadian only radio. I find no reference to a work-around for the password. The software is expensive as is the cable plus it requires a serious level of expertise to properly program this radio.
Do you really need MOTOTRBO? or any other digital or trunking capability? If not, there's lots of good radios to be had that are much easier to work with.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
That's just an 800MHz TRBO radio.
Unless it's been hit with newer firmware, you shouldn't have a problem using WireShark or a similar packet sniffing program to get the password.
