I have an Alinco DR-610 that I've had for years and now use it as a backup/portable base radio.
I've noticed that in weak VHF signal applications, the left side of the radio has good sensitivity, but the right side of the radio has decreased VHF sensitivity on the same frequency. I've tested this with several frequencies (146.760 repeater on Mazourka Peak when I'm in the Owens Valley and 162.525 weather radio in SoCal). Both are low level signals showing only one bar on the left side S meter and no bar on the right side.
The left side will break squelch on the lowest squelch setting while the right side will not. I've fully reset the radio and made sure the attenuator isn't active on the right side. I also checked under the hood for loose screws or obviously bad solder joints and couldn't find any problems.
I have not noticed this on UHF.
Any ideas?
Roger
N6YDT
Any ideas?
Roger
N6YDT
