Ok this one is very odd - and kind of disturbing.. I just found out by accident that my feed may or may not have been picking up "open mic" noise, even though there is no microphone installed on the computer (and no, it doesn't have one built in or a webcam hooked up, this is a dedicated, home built machine in a rack in a closet). I had my android app running while I was messing around in my server closet, and all of a sudden I heard the sounds of a screwdriver Plinko-ing through the rack (which had happened 30 seconds earlier) coming over the app!!
I brought up the streamer program to the VU meters and started tapping around, and found that it picks up strongest when I tap directly on the scanner itself, and I can hear myself when I talk toward the speaker!!! So like, WTF?! I know some people have complained about hearing open mic stuff on other feeds, and thats why I was careful in my own setup.. But this is maybe something everyone should check on - make sure they aren't broadcasting open mic inadvertently...
It happens regardless if the feed is plugged into the headphone or EXT jack, and it is most definitely coming into the computer via the Line In, and only on the left channel (right channel is a BC72XLT which does not seem to have this issue).. If nobody has any other suggestions as to why it's doing it or how to stop it, I'm going to open it up and disconnect the speaker.. This also showed me that what I thought was ground loop hum is actually fan noise from the network equipment and servers.
