I have a UHF VX-354 that I use for work. I'm also a ham so I wanted to program a few local ham repeaters into the radio. No problem with that except that in the W/N column in CE86 it will not let me select anything other than N, which is what it puts in by itself. It's like somewhere in the software (or radio?) it has been set to only do narrow (?).
I can "kerchunk" the repeaters but if I talk it doesn't transmit...it only "kerchunks" or "trips" the repeater when I UNKEY (we've tested this with someone else using a 440 ham HT and listening...then he talked and it came across). I can only imagine it is because of the narrow setting.
Anyone have any idea why it is 'stuck' on only allowing me to select N in the W/N column? In CE86 if I go to Hardware under Common, everything is displayed but grayed out. It does, however, show next to Channel Step "5, 6.25kHz" (see attached screenshot).
Any help would be appreciated!
_
_
