listening to Pekin Prison ?
llwade
Chillicothe Illinois
any clues how to listen to the system: Federal Correctional Institution - pekin
I am having no luck at all. any help would be appreciated
cubn
Marion/Johnson County, IN
Did you put in the settings in the database in your scanner? Last time I listened those were correct. The signal strength isn't real strong.
JD21960
ILL-annoyed
That Prison is like 35 Miles Southwest of beautiful downtown Chillicothe IL and our old Town Theater. That's a long way unless you're planning on driving by there and scanning.
ecps92
Taxachusetts
First put those frequencies in as conventional to see if you are even close-enough
These systems are designed for On-Complex coverage only and based on the Power and Antenna design are likely to not be heard much outside of the property.
If you can hear the CC on one of the frequencies, then you can experiment with adding them as a trunked system
