Larsen R03825NF Antenna
timkilbride
Linn Co Iowa
I can't find any info on this base antenna. The one I have is supposedly for 824-896mhz. It about 3' long and has a 2' pigtail coming out the bottom with a female N connector on it.
Tim
cmdrwill
So Cali
We had WAY too many problems with them. They are just a 20 gauge steel wire with piss poor copper plating for a element in a fiberglass tube. JUNK....
teufler
ST PETERS, MISSOURI
well if you do not need the pig tail, which you could always make one up, MAXRAD has a MFB-8353 ot a ANTENNEX FG8065. bOTH BASE ANTENNAS for 823-890. I was sales mager for a business 800 trunking company and these were the antennas that were used. They were not cheap, held up good. If price was a problem, we use a larsen 5/8 wave over a 5/8 th wave over a quarter wave with a ground plane kit attached. The same height, about 24 inches, n connctors. I'm using the MAXRAD antenna, good 800 trucking antenna. Small, not really noticeable to the neighbors. Been up for years, still looks the same as the day it was put up. Now I don't know wht the connections are like in the fiberglass saince they have nbevefr come apart to be exposed to the elements.
