Base Station Power Supply (TK-7180 & TK-8180)
kayn1n32008
ØÆSØ
Sector 001
How can i get a tk-7180 and tk-8180 stacked together to run off the same power supply? I'm trying to make it a clean setup so that the radios are stacked and look much like the setup in the link below only the radios would be stacked together.
Buy a third bracket.
1) Bolt '1' & '2' together.
2) Mount radio 2 in bracket '1'.
3)Bolt bracket 3 to the top of your power supply.
4)Clamshell radio 1 between brackets '2' and '3' by lining up the bolt holes in the slots in bracket '2' & '3' and bolt in radio 1.
Note: You will have to remove and drill the cover of your power supply though.
In the photo, I have a TM-V71 as radio 1, and the NX-700 is radio 2. It's not going to look exactly like your link but if done carefully it can look clean. While mine does not look perfect, it does what I need it to do in my work truck
I sketched what the photo shows, note how the clamshell end brackets fit together
Sent from my iPad using Tapatalk
Colton25
I want them to be enclosed like the original picture with the single radio setup. I just thought maybe astron sold a radio cover for a dual radio stack option.
kayn1n32008
ØÆSØ
Sector 001
Yea, I do not think they make an option like that. You may want to call them and explain what you are looking for... Never know, they may have something that is not published.
Colton25
Yeah, do you know of any other manufacture that makes radio cabinets that are similar to what I want to do. I know I've seen some that are built to have the radios side by side. Even though these aren't radios this is the kind of idea I have.
ICOM SRP REPEATER SERIES | Foresolutions
Probably an easy solution would be to purchase the mobile face plates for those radios. I've seen people that have constructed vertical mounts that hold the radios with the power supply in the base.
Other option would be to find a 19" rack mount designed for repeaters. You can fit two of these radio side by side.
