My x36s will show CTCSS/CDCSS/NAC on a search.
(no setting to select anything other than that on searches)\
On Scanning, you need the channel audio set for ALL (not analog only or digital only)
Voyager, the following comments about Tone/Nac search relate to the x96XT.
You are correct, in that the x36HP will display both tone and NAC during a custom search.
There is no 'All' setting anywhere in the x96XT interface. There is an 'Auto' setting in the Modulation menu, but that only presets the modulation (AM,FM,FMN & FMB etc) based on the preset bandplans.
As for the TONE/NAC search option in the x96XT (my other gripe).
Under the 'Global' Search/Close call Options menu, there is a sub-menu called TONE/CODE Search.
This setting defines whether the scanner will search or close call for a Tone (analogue) or Code (P25) signals.
In this menu, there are three options:
'Off'
'CTCSS/DCS Search'
'P25 NAC Search'
If you set this option to 'OFF', the radio will search and stop on all analogue and digital signals. So far, so good. If the receiver receives a digital signal, it will display the NAC. However, if the receiver stops on an analogue channel, it does not display the CTCSS/DCS tone.
Therein lies the problem.
If you set this setting to CTCSS/DCS the scanner will only search for analogue signals and will display the tone, but will ignore digital signals - That's fine.
If you set this setting to NAC Search, the scanner will stop on valid P25 signals only, displaying the NAC and will ignore analogue signals - That's fine..
Maybe, these options should be renamed:
'All'
Analogue only Search
P25/Digital only Search
But, with the 'All' option displaying both NAC and CTCSS codes/tones as it finds them.
The current terms are confusing and ambiguous.
Ideally, these three options should be available for each custom search group, rather that only one global setting shared across all custom search bands.
The required functions are already in the scanner, it is simply a case of tweaking the firmware to make it happen..
