BOBRR
Hello,
Sr. Citizen now, and frankly my antenna knowledge is very poor, so would like to ask the following, please.
Have a Diamond Brand RH77CA antenna that says it is usable for:
120/150/300/450/800/900 MHz.
a. Would this be a good or better antenna to use for a new Uniden HomePatrol-1
Scanner I just ordered ?
Would it "cover" most everything (all the Bands) this scanner is capable of picking up ?
I would like to monitor just about anything and everything.
b. Anything available that is significantly "better", but that is not any longer than the 15" that the length
that the Diamond is ?
c. Probably a silly question, but the only way to learn is to ask them.
Will keep scanner by bedside.
Unusual mounting problem for the antenna. Will probably try to mount higher than the scanner, and connect with some 50 ohm coax.
Question: for these vertical whips (I think that's the correct designation for them), does it matter at all
if they are pointing vertically up, or at 180 deg. pointing vertically downward ?
Is absolutely vertical usually the best orientation at all the Bands ?
Or, is the polarization so mixed up by the time any signal arrives, the polarization which i understand is purely vertical at the transmitter end is totally scrambled by the time it reaches the receiver ?
Much thanks; appreciate the help,
Bob
Bob
