Anybody have a list of all the radio IDs (iXXXXX) utilised on the King County System? I am trying to find them all but it's hard to keep going in to enter them as I find them. Thanks!
The Scannerstuff:Northwest frequency directories have beat maps with radio i.d info. .If you can't find one. I'll gladly type up the information you want.[/Q
In case someone misunderstood I did not mean the talkgroup IDs. I'll have a look tomorrow and see if I can't find it. My radio can still hold about 150 channels on the King County System so I might as well enter all the radio IDs I can.
I thought you meant the radio call identifiers. Sam Tom etc etc.
As I think im800mhz (get a load of the hubris in THAT name) tried to tell you, you're looking at tens of thousands of ID numbers, and they change A LOT. You can nail down one radio ID, only to have it change the next day, shift, or even hour. One of our fire engines, as an example, has 2 mobiles in the cab, 3 portables charging in the cab, and the officer will be carrying one as well. If you hear the officer transmitting as "Engine-xxxx" and lock that ID in as Engine-xxxx, what are you going to do when that same officer is in a command vehicle identifying himself as "Battalion-xx"? Or he ID's as Battalion-xx on one radio, then that portable dies and he switches to another? Or uses one of the mobiles?
And the traffic on Tac isn't checking WACIC/NCIC, they're looking for local (pertaining to THAT PD) info, i.e. FIRS or other info. Look at Tacoma and LARIAT.
