dwayne0564
Hello,
Back to the same GRE 500 scanner again, P25 phase 2 being rebroadcast on 800 MHz, some channels or good and other channels are garbled , my pro 197 is fine all the way around, 396T decodes well, all the way around, running 2.0 have used 2.1 firmware, neither makes a difference. suggestions, have moved scanner to different places, and used different antenna, no change. Getting ready to get a WS 1080 if I can't get a solution
