Using the cable that came with the scanner and downloaded my counties frequencies, it rebooted, now it says "nothing enabled", I don't know what to do next, Ive been all thru this booklet, can someone help me out?
The Whistler WS1040 is the same as the old Radio Shack PRO-106 and the old GRE PSR500.
To turn your scan lists on or off, just press keypad numbers 1, 2, or 3 and so-on depending upon which scan lists you assigned to the objects you downloaded.
