The Uniden BCD996XT or the new BCD536HP would fit the bill nicely as they're the same size as the 2096; I'd give serious thought to the 536 as it performs much better on simulcast sites like that used by Washington County (and is also Phase-II capable once the system starts using that sometime in the future).
If by "cost effective" you mean low cost, forget it. Pretty much anything that's P25 700 MHz capable (and will work reasonably well for what you want to do) is going to cost $350 or more.
My 536 does not perform better on the Washington Co Simulcast system, it is compared to my other radio's 396XT, 996, 197. But location & antenna will dictate your results. It is true the 2096 will not trunk the 700mz but using Win96 selecting extended frequencies you can receive the MARCS IP conventionally. Results will very from radio to radio of course. I still use my old 2096's in my car and truck and they receive fine, of course you will not know who you are listening to except by voice. I just entered Frequencies of the system except the control channel. My 96 does not receive the out of band 700mz very good at all. You may want to try this till you can get a scanner that will trunk the new MARCS IP. OSP is still on the MARCS for now and you need to set your extended trunking tables using Win 96.
ChLO - ChHI - Step - Offset - Base
440 - 559 - 25.000 - 440 - 851.025000
000 - 719 - 25.000 - 0 - 851.012500
