So im just getting into Ham Radio and I plan on buying a TH-9800 and I found every thing else to go with this radio (antenna and cables). But I can't find a power supply for it. It needs a 12-14 volt and 8-15 amp power supply. I was looking at 12v car battery maintainers but they don't have the amps and if they do they are expensive.
Fuses:
20 amp power cable
15 amp transceiver
Links: (if you have the time could you please check if my cable and antenna are compatible with this radio)
Radio=
Amazon.com : TYT Quad Band Transceiver 10M/6M/2M/70cm VHF/UHF TH-9800 Two Way and Amateur Radio : Car Electronics
Antenna Cable=
Amazon.com: Times Microwave LMR-400 PL259 Coax Ham or CB Radio Jumper Antenna Coaxial UHF VHF HF Coax Cable Jumper RF Transmission Line PL-259 Connectors - Made in USA - (LMR400 10 ft): Electronics
Antenna=
Amazon.com : HH-9900 Antenna for TH-9800 quad band Mobile Transceiver Radio : Car Electronics
*BTW this is my first post ever on here*
Thanks for any help here anyone can provide, it is much appreciated
Fuses:
20 amp power cable
15 amp transceiver
Radio=
Antenna Cable=
Antenna=
