XPR-8300 Multi-Channel Function
BlueDevil
WA
Is the Motorola XPR-8300 repeater capable of operating as a "Community Repeater"?
cabletech
Puget Sound
Brandon, Any repeater can be set up as a "Community Repeater".
The difference between a community and a private repeater is in who owns it and has access to it.
With a Community repeater, some one owns it and then rents time on it to others. This takes a lot of time and money plus FCC licensing to set up.
A private repeater is owned by a company or group just for that company or group.
IE--Fire department is a private system in that only fire department personal are allowed to use it.
com501
I think the OP had a different answer in mind.
The XPR series can only decode/encode one pair of tones or one digital channel at a time.
If you want to do a community repeater you can add a Zetron tone panel to the accessory connector on the rear. Zetron is supported by Motorola and there is an application note from Zetron for that.
hitechRadio
COM501 is right for analog.
If the OP is speaking in terms of Community repeater for the XPR-8300 operating Digital mode. The answer is yes also. And no Zetron community panel needed.
BlueDevil
WA
Thanks for the information. I am referring to Community Repeater as being able to decode/encode multiple PL tones. I have a VXR-7000 which performs this feature nicely. I wasn't sure if this was a stock/standard feature of the XPR-8300.
