Motorola V for Pager Decoding - Help
LordJ
South-Eastern, Ontario
I thought I would be able to use the earphone jack to send audio for PDW decoding. The volume level is way too low to decode anything. Anyone have experience with this that can help with a suggestion?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
You can crank the pager wide open which might give you enough audio to use, but that may require an attenuated patch cord.
You will have much better luck grabbing the audio off the charger/amplifier's rear plug. If you don't have a charger/amp available, they're on Ebay.
