Tried new Unitrunker version .. and it will not work. I was wanting to upgrade as I have noticed that at times .. Unitrunker will STALL .. and the affiliations will not display. The transmissions are fine.
It is saying .. invalid install. No working folder.
My data folder has never moved.
It is at ... "C:\Users\XXXXXX\AppData\Local\VirtualStore\Program Files (x86)\UniTrunker"
The Uniform.exe file is at .. "C:\Program Files (x86)\Unitrunker\Uniform.exe"
Anyone with any ideas .. ?
I did run the install with NO changes .. just the defaults and created a new shortcut to the program.
I have uninstalled it .. and reinstalled it, same issues. I know in the old days .. it used to prompt you for your data folder if I remember correctly .. how do I get it to do that ?
Well ... progress, kinda. I just over wrote my Unitrunker folder with my backup. I backup my drive every morning. So I am back to the old version .. and it works fine. I am not sure if I will have the stalling affiliations problem again.
I know this .. as I have Etrunker running at the same time on a different computer and it is receiving the affiliations just fine.
