Will all new Unidens from this point forward have USB power and charging or will it just be portables? Even though base/mobiles don't have a rechargeable battery pack, USB power might be handy.
It would be nice to have a jack to charge and one to run radio with, doing one or the other SUCKS
David Kb7uns
Simple solution. Don't use the scanner as a battery charger. Buy a battery charger. Solves your issue and results in a better, safer charge.
Simple mind your own business, I will use the charger inside the radio during the day between stops the MAHA is for use at the end of the day.
David Kb7uns
he will learn the hard way that continously charging with built in charger will eventually tear up the radio. experence is a good teacher by the way take a zanax
We should just be grateful that Uniden decided to keep the AA design over going with a sealed system like cell phones and ipods. Allows for multiple sets of batteries to be kept in a charged state and swapped out as necessary, or for use with just one set. While I do not agree with charging AAs in the radio, I understand the OPs need. Any additional components equal additional costs, and I, for one, don't want to see price go up for something I won't use. My recommendation is additional sets of batteries-Energizer used to make a 15 minute charger that had both AC and DC power cables-allowed me to ensure all of my AAs were ready to go (I replace all of my AAs annually-about 45 total for scanners, flashes and backup camera power)
Have one of the Energizer 15 minute chargers and they hammer the hell out of the batteries, will not use it anymore, what is wrong with a 100ma maintaining charge.
David Kb7uns
I don't take the battery of my Motorola ht to charge it, no reason I should have to do the same with a scanner.
DFK435's issue is that the radio is unable to keep up with his needs on the internal charger. If your /\/\ portable wasn't keeping it's charge throughout your intended work cycle, would you not be swapping out with an additional battery that was on the charger without the portable attached? That in mind, I currently get 2-3 8 hour shifts off of my relatively new Motorola batteries, but there is always one on the charger ready to go-my portable never goes into the charger. Not because it isn't designed to, but because if something goes wrong, I still have a radio.
