Here's how I add pictures:
Hi I'm a relatively new user and would like to know how I post pics relating to a thread I either start or comment on. Someone told me to use imur.com and get a code to post the pic but I would like to know if there is another option. Thanks.
Here's how I do it:
First I click on the
Quote link at the bottom right corner of the thread window. Now you have a new window opened up called
Reply to Thread.
You can enter whatever text you want in the body of that thread window and when your done, scroll down to where you see, under where it says
Additional Options, you will see a light blue bar with the words
Manage Attachments in it.
Click on that light blue colored bar and a new window will open up that looks like the picture below in the
Attached Images area.
Now you need to click the Browse button you see there, another window will open up called-File Upload. Search your hard drive via this window and select the picture/file you want uploaded.
Once you find the picture/file you want uploaded, select it, it'll then be highlighted all in blue, click on the Open button in the lower right side of that window and you will return to the
Manage Attachments window.
Now click on the
Upload button that is highlighted in light blue and the picture will be posted to the thread.
The ONLY way you'll be able to see the picture once you've done all the above steps correctly, is to do a
Preview Post- you can find this button right below the different smilie icons, highlighted in light blue color. Click on the
Preview Post button and if all went well, you will see the picture in the Preview window that opens up (the body of the message you were typing in will be right below that Preview Post message, just scroll down a bit to see it).
What I haven't figured out is, if there's a way to put the picture I just uploaded, in a certain spot in my thread, rather than have it show up at the bottom of my message like where this
Manage Attachments pictured ended up.
This is how I add pictures to my posts. I'm not sure if there's an easier way but this works for me.
Good Luck and have fun.....
