TK-7150 Beeping
Ahwahnee
Oakhurst,CA
I have a 7150 that I was getting programmed and ready to install and had running on the bench here. After a couple of weeks it started to beep in about 2 beeps per second while at the same time it stopped receiving. Turning it off for several minutes stops it. Then after its been on a few hours it will do it again. It is in the conventional mode with no fleet sync options enabled. Anybody got any ideas? None of the programming settings give me any hint as to what might be going on.
jim202
New Orleans region
That sounds logical. Do you think a local radio shop can make such a repair?
You know it would help if you let the group know what range the radio is in and where it was programmed before you made the changes.
I also have to agree with MTS2000des that your VCO has probably gone out of lock. It's not that hard to fix, but you should have told the group some more of the facts involved here about the problems.
wireless_friendly
Banned
Check frequencies programmed and radio frequency range. Or just pass throught channels with different frequencies.
