I have a a headphone plug with two male 1/8" plugs that I am plugging into the headphone jacks of a 536HP and another scanner, either a PRO-197, WS-1080, or 996XT. The audio from both plugs goes to one pair of headphones using the other end ot the cable with a single female 1/8" jack. However, I did this only for a while then stopped. The reason: Started to get popping sound in 536HP, the scanner actually shut off and restarted, the P25 audio was distorted, and I went "Oh s..."
When pulled the dual set up headphone jack, no problem with the 536HP. Seems like I am getting some type of DC voltage loop in the 536HP when I have the ground connection of the plug physically connected to another scanner at the same time. This happened one time about 3 months ago, but forgot, and plugged the dual headphone cable into tonight with same problem.
Obviously, I won't do that again. But does anyone know what might be going on to cause this behavior. The problem is that I would like to use one pair of headphones to monitor more than one scanner at a time when my wife is sleeping. Is there some way to do this properly where I would not get this type of behavior?
Would an audio mixer be good in this type of situation?
Any advice would be appreciated.
Steve AA6IO
Steve AA6IO
