Question about battery charger for Baofeng
jaspence
Michigan
Charger
It is not the best practice, especially in the cheap radios. High end radios have a circuit that reduces the charge to a trickle or maintenance charge after the battery reaches full voltage, but it's anyone's guess what the circuit in a low end radio has for protection. Unless you are sure of the charger specs, I would not leave it in the charger.
nd5y
Wichita Falls, TX
When lithium-ion batteries in consumer type portable devices are fully charged the charger shuts off. It doesn't trickle charge or float charge them. It should be OK to leave them in a properly functioning charger.
jonwienke
More Info Coming Soon!
VA
The Baofeng chargers change LED color to correspond with charge mode. The LED turns green and absence of heat from the battery indicates the charger is shutting off when the battery is fully charged. I have a radio I leave on the charger and it hasn't had any ill effect on the battery so far.
wildbill0013
i agree 100%, i have 3 wouxun kguv3d radios and 1 kguv8d also 1 baofeng portable that i leave in my chargers after i come home from work and in the last three years i have not had 1 problem with any of them.
DaveH
Ottawa, Ont.
Probably not a good idea to leave the radio on while in the charger, as the drain affects the charger sensing end of charge..current dropping off to a few percent of full charge rate in constant voltage stage, for Li-ion.
KC9HI
Uh huh. So when I pull the battery off my Moto radio and drop it in the charger, exactly how does the radio perform this magic?
I believe the intent was to say [The chargers that come with] "High end radios have a circuit..."
Jim KC9HI
KC9HI
There is no temperature sensing in the Baofeng chargers (the center "T" contact is not even connected internally).
Jim KC9HI
