I finally received a Yagi antenna for the Virginia Beach ORION frequencies. I have had a lot of problem receiving clear signals. I temporally set up a mast and the antenna. Hooked up my Pro-106, set to analyze and started to find the sweet spot. Well I am not sure there is one. At times my signal is in the 90's and then it jumps to the low 80's to high 70's. Making sure I rotated the mast just a little.
I have read where multi-site is many sites, different frequencies, and possibly groups. I believe here in Va. Beach there are several sites, but all have the same frequencies and groups. I am sitting between two of these sites, so I thought this was the problem with my reception.
Any suggestions from you guys and gals on how to properly "aim" the antenna would be appreciated.
