I read you should not place J-poles close to metal objects, but I am not sure if this is ok. The "J" part is completely over the rain cover.
And yes, I actually passed the coax down the chimney but I am planning to use an electrical service weatherhead to go through the roof.
For some reason the top brick I tried to drill through was much harder than the others and my masonary/mortar bit (forget what it is called exactly) couldn't handle it. I relocated that clamp (everything is soldered). Just wanted to mention that in case anyone tries this.
Thanks.
Thanks.
