I'm using a discriminator tapped scanner and DSD+ to listen to a very small local public safety agency that uses a conventional TRBO VHF repeater, with no problems. Using DSD+ and the scanner I am able to hear audio just fine, and have identified the relevant frequency, time slot, color code and talkgroup of sheriff dispatch when near the PC.
I recently purchased a CS701, thinking this would give me a convenient way to monitor the same radio traffic on the go. So far, I haven't been able to get it to work. I'm struggling to imagine what could cause a CS701, which appears to be properly programmed, to not pass voice traffic on channels I can monitor just fine using DSD+ on the PC.
To program the CS701, in the Digital Contact tab, I set a Contact Name of Sheriff Dispatch, selected a Call Type of "Group Call" and entered the talkgroup number from DSD+ into the "Call ID" field.
I then created a Group List called Sheriff Dispatch under the Digital RX Group Call tab, and added the "Sheriff Dispatch" Contact to the "Contact Member" field.
In the "Channel Information" tab, I set the "Channel Mode" to "Digital," entered a Channel Name of "Sheriff Dispatch", entered the RX and TX frequencies (the same, since I'll only monitor anyway), and checked the "RX Only" box (though I've also tried unchecking this). Under "Digital Data," I set the Contact Name to "None" since I won't be transmitting (though I've also tried setting this to Sheriff Dispatch), set the Group List field to "Sheriff Dispatch," set the Color Code to the CC I found using DSD+, and set "Repeater Slot" to the time slot I found using DSD+.
I created a Zone, and put the channel Sheriff Dispatch in that zone. Then I programmed the radio. I powered up the CS701 and it displays "Sheriff Dispatch." When there is voice traffic on Sheriff Dispatch on DSD+, I hear it fine through the PC, but do not hear the voice audio through the CS701. When there is voice traffic on Sheriff Dispatch on DSD+, the green light on the CS701 lights up, and the signal meter on the screen goes to full scale. But no audio. Pressing the Monitor button (side button 1) does nothing.
Thinking this could be as simple as a bad speaker in the CS701, I programmed an analog frequency and transmitted on another radio. The CS701 passed that audio just fine.
Anyone have any ideas what could be the issue here?
So very puzzling that I hear voice audio just fine on DSD+, and the CS701 is clearly receiving the signal based on the green LED and signal meter, but audio isn't passing through the CS701's speaker. Of course, I double checked that the programmed Group Call number matches the numbers that follow "TG=" in DSD+, and that this is in fact a Group Call (DSD+ displays "Group Call; TG=###### RID=######## Slot=2").
Dan
Dan
