paranoia11
I look at 2 websites that sell and program scanners, bear cat warehouse, and scanner master.
which one is the best to use, here in southern Maine.
hi paranoia11 i just purchased the 536 package at scannermaster i am from southern maine also
As the 536hp/436hp are programed to a micro-SD. You can buy it anywhere, Amazon had some good deals in the past month, just have someone with the software program up a micro-SD for you and pop it in the mail.
If you need an SD programmed drop me a line, I should have a few micro-SDs laying around, happy to get one programmed up and sent off.
- Removed - Attachment Won't Attach -
Attached is a PDF of what I have set up for Southern Maine. I have NHSP in there for when I am on the border. The Federal stuff (the NAC's for some reason are not on the PDF) has CT/MA/RI in there, but many of those Freqs apply to Maine ... although that system was not intended to be part of the PDF.
yes the 536 is being programed for my area but i will be adding on to it myself
the sales rep from one of the scanner dealers, told me that if the frec. are not already in them it does not let you manually add it, on that model.
