Pro-163
Ok, I been playing with my new toy and I understand that I may not be able to listen to the local police but I should be able to hear the Belmont county fire and sheriff frequency right?
This is my issue, I can't seem to program the "trunk" correctly. I'm not sure what parts of the trunk system that I need to enter, the scanner asks for frequency's during programming but I only see one on the list. If I program just this one I can hear the dispatch send out the EMS but thats all I hear, no responses from the EMS or anything. Any help is appreciated.
Chris
G'day Chris,
I have three [3] Pro-163s and also a Pro-164 which is the HandHeld version of the same.
I live in northern Arizona [just south of the Canyon] and though it is pretty sparce out here, there's lots of analog [conventional] stuff to listen to. Of course I have a couple of lengths of 2" pipe with a Discone Antenna outside, and also a Glass-mount Antenna on my truck and a PVC telescopic [homemade] on my 5th Wheel with a Discone Antenna [removeable] mounted on that. At least two of my radios go with me wherever.
I use ARC-300 to program these Radios, and as I go, I also Clone from one to the other. Believe me, the Programming Software [no matter which one], is definitely worth the $$$$$. Makes life so easy.
Using Radio Reference, I program the first 4 banks as separate County Banks: Mohave,Yavapai,Coconino, Navajo/Apache [together] and Arizona Statewide. Then I use Banks 5 & 6 for Other States, 7 for US Forest Svc, 8 for Railroad and 9 for Aircraft/Airports.
If I decide to go on a trip, then with the aid of the ARC-300 software and the RS 20-047 interface cable, I can program and save [in my laptop] a new program for my trip. SUPER EASY.
One would think that with these radios I'd be satisfied. Well, my wife just gave me a brand new Pro-652 [Digital scanner] and now I have a NEW LEARNING CURVE!
I'm using the ARC-500 software for that one, and have just [today] started learning both the Radio and the Software. Phew!!! Looks promising, but is a whole new setup and is a bit confusing. Gotta get some advice etc on setting this one up.
Good luck Chris.
