Good Day:
I'm trying to get a feed running that is having issues. I'm running it on a Raspberry Pi B model, with the image that DC31 provided. Works well with TTD, but trying to feed RR/Broadcastify it's continually going up and down. Seems to run for about 7 minutes and then shutdown, and then comes back about 15 minutes later.
I've tried running it manually so I could do some verbose, and this morning was seeing a BufferSink decrease until it failed. This afternoon I'm not seeing those errors but it continues to drop and come back.
Looking for any suggestions, nothing I've found on google has yet given me the ah ha moment...
Chuck
pi@tride-ttd ~ $ darkice -v9
DarkIce 1.0 live audio streamer, darkice - DarkIce is a live audio streamer. - Google Project Hosting
Copyright (c) 2000-2007, Tyrell Hungary, Tyrell Hungary Corporation
Copyright (c) 2008-2010, Akos Maroy and Rafael Diniz
This is free software, and you are welcome to redistribute it
under the terms of The GNU General Public License version 3 or
any later version.
Using config file: /etc/darkice.cfg
11-Dec-2014 10:24:49 Using ALSA DSP input device: pulse
11-Dec-2014 10:24:49 encoding
11-Dec-2014 10:24:49 scheduler high priority 99
11-Dec-2014 10:24:49 Could not set POSIX real-time scheduling, this may cause recording skips.
Try to run darkice as the super-user.
11-Dec-2014 10:24:50 set lame mode 3
11-Dec-2014 10:24:50 set lame channels 1
11-Dec-2014 10:24:50 set lame in sample rate 11025
11-Dec-2014 10:24:50 set lame out sample rate 11025
11-Dec-2014 10:24:50 set lame bit rate 16
11-Dec-2014 10:24:50 set lame quality 9
11-Dec-2014 10:24:50 set lame lowpass frequency 3000
11-Dec-2014 10:24:50 set lame highpass frequency 0
11-Dec-2014 10:24:50 set lame psycho acoustic model 1
11-Dec-2014 10:24:50 set lame error protection 1
LAME 3.99.5 32bits (LAME MP3 Encoder)
Using polyphase lowpass filter, transition band: 2890 Hz - 3023 Hz
11-Dec-2014 10:24:50 MultiThreadedConnector :: tranfer, bytes 0
11-Dec-2014 10:24:50 MultiThreadedConnector :: ThreadData :: threadFunction, was (thread, priority, type): 0x6667f8 0 SCHED_OTHER
11-Dec-2014 10:24:50 MultiThreadedConnector :: ThreadData :: threadFunction, now is (thread, priority, type): 0x6667f8 0 SCHED_OTHER
11-Dec-2014 10:38:05 BufferedSink, new peak: 423
11-Dec-2014 10:38:05 BufferedSink, remaining: 1625
11-Dec-2014 10:38:05 BufferedSink, new peak: 854
11-Dec-2014 10:38:05 BufferedSink, remaining: 1194
11-Dec-2014 10:38:05 BufferedSink, new peak: 1171
11-Dec-2014 10:38:05 BufferedSink, remaining: 877
11-Dec-2014 10:38:06 BufferedSink, new peak: 1579
11-Dec-2014 10:38:06 BufferedSink, remaining: 469
11-Dec-2014 10:38:06 BufferedSink, new peak: 1887
11-Dec-2014 10:38:06 BufferedSink, remaining: 161
11-Dec-2014 10:38:06 BufferedSink, new peak: 2047
11-Dec-2014 10:54:07 MultiThreadedConnector :: sinkThread reconnecting 0
11-Dec-2014 10:54:07 couldn't write all from encoder to underlying sink 570
11-Dec-2014 10:54:23 MultiThreadedConnector :: sinkThread reconnecting 0
11-Dec-2014 10:54:24 set lame mode 3
11-Dec-2014 10:54:24 set lame channels 1
11-Dec-2014 10:54:24 set lame in sample rate 11025
11-Dec-2014 10:54:24 set lame out sample rate 11025
11-Dec-2014 10:54:24 set lame bit rate 16
11-Dec-2014 10:54:24 set lame quality 9
11-Dec-2014 10:54:24 set lame lowpass frequency 3000
11-Dec-2014 10:54:24 set lame highpass frequency 0
11-Dec-2014 10:54:24 set lame psycho acoustic model 1
11-Dec-2014 10:54:24 set lame error protection 1
11-Dec-2014 11:16:07 MultiThreadedConnector :: sinkThread reconnecting 0
11-Dec-2014 11:16:07 couldn't write all from encoder to underlying sink 574
11-Dec-2014 11:16:23 MultiThreadedConnector :: sinkThread reconnecting 0
11-Dec-2014 11:16:24 set lame mode 3
11-Dec-2014 11:16:24 set lame channels 1
11-Dec-2014 11:16:24 set lame in sample rate 11025
11-Dec-2014 11:16:24 set lame out sample rate 11025
11-Dec-2014 11:16:24 set lame bit rate 16
11-Dec-2014 11:16:24 set lame quality 9
11-Dec-2014 11:16:24 set lame lowpass frequency 3000
11-Dec-2014 11:16:24 set lame highpass frequency 0
11-Dec-2014 11:16:24 set lame psycho acoustic model 1
11-Dec-2014 11:16:24 set lame error protection 1
11-Dec-2014 11:39:08 MultiThreadedConnector :: sinkThread reconnecting 0
11-Dec-2014 11:39:08 couldn't write all from encoder to underlying sink 567
11-Dec-2014 11:39:24 MultiThreadedConnector :: sinkThread reconnecting 0
11-Dec-2014 11:39:25 set lame mode 3
11-Dec-2014 11:39:25 set lame channels 1
11-Dec-2014 11:39:25 set lame in sample rate 11025
11-Dec-2014 11:39:25 set lame out sample rate 11025
11-Dec-2014 11:39:25 set lame bit rate 16
11-Dec-2014 11:39:25 set lame quality 9
11-Dec-2014 11:39:25 set lame lowpass frequency 3000
11-Dec-2014 11:39:25 set lame highpass frequency 0
11-Dec-2014 11:39:25 set lame psycho acoustic model 1
11-Dec-2014 11:39:25 set lame error protection 1
11-Dec-2014 12:02:38 MultiThreadedConnector :: sinkThread reconnecting 0
11-Dec-2014 12:02:38 couldn't write all from encoder to underlying sink 684
11-Dec-2014 12:02:54 MultiThreadedConnector :: sinkThread reconnecting 0
11-Dec-2014 12:02:55 set lame mode 3
11-Dec-2014 12:02:55 set lame channels 1
11-Dec-2014 12:02:55 set lame in sample rate 11025
11-Dec-2014 12:02:55 set lame out sample rate 11025
11-Dec-2014 12:02:55 set lame bit rate 16
11-Dec-2014 12:02:55 set lame quality 9
11-Dec-2014 12:02:55 set lame lowpass frequency 3000
11-Dec-2014 12:02:55 set lame highpass frequency 0
11-Dec-2014 12:02:55 set lame psycho acoustic model 1
11-Dec-2014 12:02:55 set lame error protection 1
11-Dec-2014 12:24:09 MultiThreadedConnector :: sinkThread reconnecting 0
11-Dec-2014 12:24:09 couldn't write all from encoder to underlying sink 568
11-Dec-2014 12:24:25 MultiThreadedConnector :: sinkThread reconnecting 0
11-Dec-2014 12:24:26 set lame mode 3
11-Dec-2014 12:24:26 set lame channels 1
11-Dec-2014 12:24:26 set lame in sample rate 11025
11-Dec-2014 12:24:26 set lame out sample rate 11025
11-Dec-2014 12:24:26 set lame bit rate 16
11-Dec-2014 12:24:26 set lame quality 9
11-Dec-2014 12:24:26 set lame lowpass frequency 3000
11-Dec-2014 12:24:26 set lame highpass frequency 0
11-Dec-2014 12:24:26 set lame psycho acoustic model 1
11-Dec-2014 12:24:26 set lame error protection 1
Chuck
any later version.
