From the BCD396XT Complete Reference Manual (noting that the 996XTs function the same way as the 396XTs):
Priority ID Scanning
Trunked channels can be assigned priority. When the scanner is monitoring the control channel, channels you tag as priority are given a higher priority over non-priority channels when they become active.
"Priority ID Scan
Priority ID Scan works in ID Scan/Search Mode or ID Scan/Search Hold Mode when the Priority ID Scan setting is on.
This works on Motorola and EDACS (Wide, Narrow), LTR, and P25 Standard systems.
This function is very similar to conventional priority although there is no “interrupt” during the transmission. Priorities are checked in between transmissions, when the scanner is receiving the control channel, as during the channel delay period."
Be sure to check the Priority ID Scan box (below where it says XT options in the trunked systems Setup screen) and that you have checked the PRI boxes for those talkgroups you wish to be priority.
Priority Scanning and Priority ID Scanning are similar, but different.
Priority scanning is for conventional systems. When this occurs, you will notice that "interrupt" as the scanner looks at a priority frequency for activity.
Priority ID scanning is for trunked systems. This happens in the background and isn't noticed until a priority talkgroup becomes active.
Here is a critical point: You are scanning both conventional and trunked "stuff" and a trunked system set up for Priority ID scanning. If the scanner has stopped on a conventional channel, it does NOT periodically check the trunked system for activity on a priority talkgroup. Priority ID scanning happens only when the scanner is "listening" to the control channel for the trunked system.
