Apostrophe in Alpha Tag throws SQL error
w2lie
New York DB Admin
Long Island, NY
I attempted to add an apostrophe into an alpha tag using the import function and the result was a SQL error. Removing the apostrophe from the alpha tag allowed me to import correctly.
For security reasons, I don't think I should put the SQL output in a public forum, but if anyone want to try, this is the line that cause the failure:
Code:
152.45  167.9 PL  Stuart's Taxi (Westbury)  Stewart's  WQTP682  FMN  BM  Business
QDP2012
Apostrophe's should not be allowed (as commands, at the injection-point). In other DBMSs, that is a serious vulnerability, and likely is here (in the above described situation), too.
eorange
♦Insane Asylum Premium Member♦
Cleveland, OH
An apostrophe can certainly be allowed. That's not the problem.
The problem is whomever wrote the software that updates the database didn't prevent user input from being interpreted as literal SQL commands.
QDP2012
Correct. I added clarification to my earlier statement which should have been included originally.
D
DaveNF2G
Guest
The solution is to put two apostrophes (not a double quote) where you want one to appear in the data.
"Stuart''s Taxi" should work.
