Im sorry if this is a dumb question or has been asked before but I have searched the threads and can't seem to find the answer I'm looking for.
Is there a way to force DSDPlus to output to two seperate devices?
I am using unitrunker 1.0.30.10 and DSDPlus-1.51 with two RTL2832U dongles which is working flawlessly to trunk track fleetnet 2, both analog and digital
I want to feed the output audio from DSDPlus to a line3 virtual (5th output device) as well as to my speakers (1st output device) this way I can feed just the dsd audio to a broadcast stream through line3 while at the same time output it to my speakers
I have tried it by simply adding -o5 -o1 but it will only take the last output entered in the command line
I had it setup where I was broadcasting audio from primary sound capture driver but all other sounds from windows as well as the digital noise came through on the feed
any help is greatly appreciated
